Home > Technical (L322) > FBH relay question
mbmarkyb
United Kingdom 2003 Range Rover Vogue Td6 Bonatti Grey
FBH relay question
2002 model TD6 Vogue - FBH not working so had it out stripped cleaned and it looked in good condition. glow plug working etc. i have it on a remote so the fan starts, pump starts fans in the car etc as i have aux heating on the display. no fuel . looking at rave there is fuse 59 and it also mentions 69, will check 69 in a moment but no mention of a relay?
I also presume i can open the fuel tank access and get to the pump from there, anyone done this?
Post #309407 31st Jan 2015 8:02am
No relay involved.
These are the wiring diagrams. Sorry about the quality, it's the system.
If you require the wiring diagrams pm me.
Post #309427 31st Jan 2015 10:07am
sasdiscos
United Kingdom 2010 Range Rover Vogue SE TDV8 Zambezi Silver
I thought it was permeant live, and then w bus for the control.
Steve You remind me of a young me, not much younger mind, perhaps even a little older!
Post #309429 31st Jan 2015 10:08am
mbmarkyb
Found it in rave to thank you for posting. I think.I either have a ecu board problem on the fbh as it also suffers with fan being on when you.open doors etc or a pump or a connection . will see if I can access the pump and.test for power etc this afternoon
Post #309443 31st Jan 2015 11:29am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
http://www.fullfatrr.com/forum/topic23111.html?highlight=paulb
Post #309453 31st Jan 2015 12:32pm
mbmarkyb
Thanks for the responses and links will get in touch with mike Very Happy
Post #309504 31st Jan 2015 7:37pm
Doh, sorry, misread FBH for FSR Rolling Eyes Got - 2017 SDV8 Autobiography in Loire Blue
Post #309505 31st Jan 2015 7:46pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
FBH fuel pump is not in the tank,its on a rubber bracket above and to the front of the tank
when the heater starts up it should run for about 28 seconds, die down a bit then after about another 5 seconds you should hear the fuel pump start to tick if this happens the heater part of it is fine, it stands a chance you have a fuel blockage
i have came across 2 in the last week with the fuel pipe into the burner blocked solid with carbon= but it needs open heart surgery to clean it out and a welder to put it back together
burner housing
cut the 3 welds off with a dremmal
part you should end up with after cutting welds off
remove cir clip that holds metal gauze and felt gauze underneath
carbon blocking fuel delivery hole
hole aftre clean up
new gauze fitted £22 off ebay (picture did not come out)
3 tack welds holding it back together
otherwise if it behaves differentaly
IF stop after 3 sec, restart 4 seconds later and finally stop at 2 minutes 7 sec;
An error is generated; may be caused by:
-Battery voltage lower than 10 volts
-Glow plug open or short circuit
-Circulation pump open or short circuit
-Fuel pump open
-PCB defective
IF a weird turbine noise appears at a door opening e.g.,PCB likely faulty.
IF stop after more than 2 minutes 10 sec, then
PCB and all devices are good (except doubtful glow plug)
IF stop at 4 minutes 5 sec, Glow plug resistor too high (0,6 ohms for instance),
IF stop at 4 minutes 40 sec it is a ignition fault, (fuel pump priming fault e.g.) = blockage in burner
http://www.the75andztclub.co.uk/forum/showthread.php?t=100297
Post #309516 31st Jan 2015 8:28pm
mbmarkyb
ta for info again. got the pump out . was just a mass of rust . tried on a 12v source and just click nothing tested connector and I have power . New pump ordered. I am still suspecting pub but will change this first
Post #311560 8th Feb 2015 5:19pm
ironhorse
the pump does just click once when you power it up
you need to keep on/off on/off on/off with the power to see if it draws any fuel through it
Post #311576 8th Feb 2015 6:04pm
mbmarkyb
if that is the case then it maybe ok apart from one end of the metal pipe just broke off.
I did expect it to just tick away as the voltage on my meter stayed around 10:30 to 11v when i connected to the fuel pump connector on the car( not the best connection) so it didn't pulse . when i pressed the remote i could hear the fan start, water pump and then the glow plug as that took some volts and slowed the fan for a moment. I will attempt to blow the pipes through before i fit the new pump.
After that it will be the blockage you mentioned above or and the PCB board.
I will do some photos too as forgot today
Post #311621 8th Feb 2015 8:14pm
mbmarkyb
saw a few like this and still working
Post #311623 8th Feb 2015 8:19pm
