Windscreen smear from new flat aero wipers | |
Hi all,
I've just fitted the new aero flat front wiper blades as was recommended on here!
Whilst it's very hard to photograph (but I've tried), the wipers are leaving a smear across the top third of the drivers side of the windscreen. Possibly in the worst place, in the driver's eye line, especially poor in bad driving conditions.
If you open up the full size picture copied in below, you should be able to see the residual marks they leave on the windscreen......
 | Click image to enlarge |
I've taken some silicone spray and WD40 to the hinge mechanism and spring in case it wasn't sitting properly against the windscreen, but to no avail...... Further pics of the wipers below.
It's this section of the wiper that appears to be leaving the smear and not shifting all the water:
Any advice on solutions would be much appreciated
I've still got the old wipers but would be a pain to re-assemble the arms and buy new blades for them too if it can be avoided.
Thanks,
Chris 2002 Range Rover Td6 Vogue
