Home > Technical (L322) > Windscreen smear from new flat aero wipers |
Apart from a good clean of the blades and screen with Windex/alcohol etc. I don't think there is much you can do. It could just be that that part of the blade is damaged and therefore not wiping properly. MY 2010 5.0 SC Galway green and sand interior!!
8th Feb 2015 6:39am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7733 |
I've not noticed with mine, will double check next time they are on.
8th Feb 2015 8:06am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1695 |
I did notice similar when I first fitted my Aero blades. Gave the blades a good clean and that solved the problem.
8th Feb 2015 9:20am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
Swap the wipers from side to side... Do they both do it? |
8th Feb 2015 11:27am |
