Hi
A picture would help, but most likely yours is identical to older model (i.e. an actual gear lever, not the rotary knob)
To get the metal piece off, take the gear-lever off (simply pull it up) then turn it upside down, using a plastic trim tool (or a screwdriver with thick tape on it), lever the thin and narrower part of the metal trim, then lift it all up.
It is tight but you will get it. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
