Home > Maintenance & Mods (L322) > Replace battery in 2003 keyfob
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Both my keyfobs are now saying 'low battery' on the dash, I've ordered a couple of CR2016 Duracells but how hard a job is it please? Wanted to check before prizing the keyfob apart and it falling into a thousand pieces on the kitchen table
Post #309644 1st Feb 2015 12:23pm
Easy peasy.....
Prise off the back cover
Undo the two screws
Remove back of fob
Remove battery
Refit in reverse
Do one at a time, and check the key you changed the battery in works on the car before changing the other battery. Should be no problem, but better safe than sorry! .
Post #309657 1st Feb 2015 1:17pm
Sparkylee
2003 Range Rover Vogue 4.4 V8 Epsom Green
Mines just come up with the same message
Post #310858 5th Feb 2015 1:22pm
v8rich
England 2002 Range Rover HSE Td6 Bonatti Grey
Remember to peel off the sticker bit on the battery before inserting it into the key fob. Whistle
Mine didn't work first time... (Never seen that fitted on button cells before is my excuse!)
Post #310937 5th Feb 2015 6:00pm
Sparkylee
^ cheers Thumbs Up
Post #311121 6th Feb 2015 11:07am
