![]() | Home > Camping, Caravanning and Holidays > Alko ATC electrics on my 2004 L322 |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 226 ![]() ![]() ![]() |
Not a deffinatley answer I know, but I have just the genuine 13pin wiring kit to mine although have yet to test it on my van with ATC fitted.
You have two direct from the battery circuits on the tow socket on an L322, one is fused at 15A and the other is fused at 20A.
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
Just read up on the ATC system, clever that, it didn't exist when I pulled caravans.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8742 ![]() ![]() ![]() |
What wiring does your van have 13 pin..?
My van is only 12 months old so has 13 pin. (Works well with the 13 pin conversion I did on my P38). The L322 currently only has 12N - if it's an easy job to turn in to 13 pin then great |
Should be plug and play if your existing wiring is genuine Land Rover.
Only thing to note is I had real problems getting a tow bar wiring loom for my 2003 FF a couple of months ago local dealer said Land Rover don't produce them anymore.
