![]() | Home > Technical (L322) > Deployable side step problem |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I've sometimes had passenger side issues when the battery is not up to full charge. I ctek mine every couple of weeks and the problem seems to fix itself. a lot of FFRR issues are down to the battery |
Ade66 Member Since: 09 Aug 2014 Location: South Yorkshire Posts: 12 ![]() ![]() |
"ctec" ??
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
It's a brand of battery charger |
Ok....just googled and ebayed them but there's different models/types.....any recommendations ? |
Click on "search" type "ctek" and all will be revealed |
How does the motor sound (compared to the drivers side?)
To be honest I haven't sat and compared them. The only thing I've done to try and rectify the problem is to daub grease over the moving parts about 4 weeks ago but obviously this hasn't rectified the problem |
Would be a good move "me finks" sir |
Taken on board and will do |
Right.... been and had a listen. They both sound more or less the same with the passenger one (the problem side)sounding very slightly "bitty/gritty" but not much.
Bizarre! Try a hard battery reset? Only thing i can think then would be an ECU issue? |
55palfers Member Since: 26 Aug 2014 Location: Solihull Posts: 113 ![]() ![]() ![]() |
I have had the same problem ever since I got the car. AUC in September.
I feel such a jerk but whats a hard battery reset ?
