Home > Technical (L322) > Any way to tell if its front or rear FSR at fault?
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Might be a stupid question, but I'm asking anyway Embarassed My RR of 5 years has had 2 new FSR in that time and think she needs another Big Cry But have been reading about a rear FSR too, do these fail very often? Seen a million and 1 guides/videos on the front on under drivers dash, but what about the rear one, do they fail?
And if so, how would you tell which one had given up?
Post #309640 1st Feb 2015 12:13pm
No reason why the rear one shouldn't fail, although it probably gets used a lot less than the front one.
I think the only way you could test it is to use it and see if the rear fan speed varies smoothly as you change the speed by rotating the wheel up and down.
The two fsr's are totally independent of each other.
Post #309663 1st Feb 2015 1:33pm
As above but also the two are the exact same part numbers so, if one fails Whistle The other must too Thumbs Up
Post #309665 1st Feb 2015 1:35pm
Are you sure? Replaced my front FSR three times and rear fans still behaving as expected (although I don't get much heat!) .
Post #309700 1st Feb 2015 2:57pm
