Home > Maintenance & Mods (L322) > Sound of water when cornering |
Ozzy Rangie Member Since: 01 Feb 2015 Location: Perth Posts: 10 |
L322 Rangie 2002
1st Feb 2015 6:48am |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 866 |
Check the venty bit below the windscreen. Water from the screen should drain through holes that can get blocked with leaves. My Previous RR's!
1st Feb 2015 7:18am |
Hi
1st Feb 2015 7:45am |
Check the sunroof drains. Quite common with Land Rovers. |
1st Feb 2015 8:11am |
Hi
1st Feb 2015 8:24am |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
Like this?
1st Feb 2015 8:35pm |
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 |
Fuel tank. I sometimes get caught out before realising |
1st Feb 2015 10:00pm |
not fuel tank, tank is at 3/4 |
2nd Feb 2015 4:57am |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 |
My old car (Cayenne) had drainage tubes that ran along under both doors on each side. Were supposed to drain out behind the wheel arch cover at the front but this often got blocked by salt/grit/mud etc. Not sure if the RR has a similar design? |
2nd Feb 2015 9:28am |
what about this?
2nd Feb 2015 11:10am |
Thanks for that, reckon its the same problem.
2nd Feb 2015 11:43am |
