Home > Maintenance & Mods (L322) > rusty rear arches |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
I thought they all had that.....
30th Jan 2015 5:51pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16289 |
rear of the arch (near the bumper) will be almost certainly from the inside...
30th Jan 2015 5:54pm |
AndyLandy Member Since: 16 Jan 2015 Location: Salisbury Posts: 17 |
Yes, forward part of arch under door
30th Jan 2015 7:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
Yes, loads of threads on it, common problem, have a search there are a few solutions to protecting the arches once repaired. Mostly surface rust caused by stone damage. There is nothing that can't be fixed with a hammer😜😜
30th Jan 2015 7:36pm |
If you've clocked it before you buy the car, don't buy it unless they agree to fix it properly and a smart repair is no good because it will quickly return. As soon as the paintwork is properly dealt with, put a greased rubber strip on the arch to keep corrosion at bay.
31st Jan 2015 11:32am |
