Home > Technical (L322) > Alternator charging rate? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8248 |
Well it takes about 40seconds to replace the power taken out of the battery from a normal start....
29th Jan 2015 7:31pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8550 |
Was perfectly perky after a bit of a run yesterday but didn't show a full charge on the ctek initially, but to be honest I didn't really wait too long as it was snowing.....
29th Jan 2015 7:51pm |
Yep, you will look a bit silly trailing an extension lead down the road......
29th Jan 2015 10:22pm |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
I was told that 13 miles will charge it back up although I'm not sure if thats a nearly flat battery. 2020 Porsche Panamera Turbo Hybrid (V FAST)
29th Jan 2015 10:32pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
from flat and needing a booster to start, mine restarts after an 8 mile drive. Cheers
30th Jan 2015 10:43am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
JST - from flat and needing booster cables to start I suspect the 8 mile drive will give it enough to be able to start the car but will not be a full charge.
30th Jan 2015 4:17pm |
good point Ash, i misread the post, thought it was how long from a flat start to get it to restart off own battery. Cheers
30th Jan 2015 4:52pm |
I would suspect that to put a full charge into the battery from completely flat would take several hours of running, but I suppose it's an open question as it depends on how much charge is actually left in the battery.
30th Jan 2015 5:57pm |
