Home > Technical (L322) > TD6 wouldn't start this morning. |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Latest.
29th Jan 2015 6:45pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
I'm looking at 1260 Delivery Pump Control System, possibly along with the LCM eeprom fault. For these purposes you can ignore all the others. For me still pointing towards the fuel rail wiring.....
29th Jan 2015 10:43pm |
Thanks for that Joe. Im not very savvy on wiring etc. My next route will be an auto electrician I guess. No longer FF owner but still interested. Present car Jaguar XE
31st Jan 2015 1:22pm |
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 |
Sounds like an injector. I have just replaced two in my TD6
1st Feb 2015 5:38pm |
OK, it has been a while since I started this topic, as I decided to take the car off the road for a few months (its mainly used as a weekend run-around). This week I decided to try to get the car going again.
26th Apr 2015 2:30pm |
Did you not try starting it on Easy Start as suggested? 2008 Range Rover TDV8 435,000kms
26th Apr 2015 2:56pm |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 |
please what ever you are doing consider this
26th Apr 2015 3:25pm |
I did try it with easy start a while and it didn't work, but I didn't want to try for too long as I have read a few horror stories.
26th Apr 2015 5:34pm |
Tried to start it several teams while spraying Bradex easy start strait into the air filter. The engine caught briefly and run roughly for a couple of seconds. This happened 2 or 3 times but I decided to stop as I was getting loads of smoke coming out of the exhaust and it was starting to smell. Also I didn't want to do any damage to the engine. All sorts of errors started to flash on the dashboard. Fuel Injection, HDC inactive, Air suspension inactive etc etc.
30th Apr 2015 6:53pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Given that you have adequate fuel coming out of the fuel filter I would have the fuel pressure checked in the common rail whilst cranking the engine if it was me.
30th Apr 2015 7:52pm |
Hi. Just realised I forgot to post my results.
29th Aug 2015 12:30pm |
I never saw a high pressure pump gone in a TD6 yet 2008 Range Rover TDV8 435,000kms
31st Aug 2015 1:51pm |
