![]() | Home > Technical (L322) > TD6 wouldn't start this morning. |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Check you are getting fuel delivered. release a pipe at the fuel filter and with suitable receptacle to catch fluid turn on ignition. fuel should flow! If not secondary fuel pump might need a bash with a hammer (under rear passenger side) or worse the primary one in the tank. Seems most likely cause, unless several of your injectors packed up at once or your fuel rail wiring has gone up the swanee? .
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
Thanks for quick reply.
If you are unlucky enough to have "summer" diesel in the tank than waxing is a possibility. You could put a few liters of petrol in and run it for a bit while it is warmish during the day and hope that is enough and then fill up with winter diesel asap.
I have never seen diesel sold as summer or winter fuel in GB No longer FF owner but still interested. Present car Jaguar XE
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
Uk diesel will start waxing around -20 degrees according to google so i dont think thats your problem.. ... - .- -.
Quick update.
Well finally managed to get time to check out the car.
Starting (excuse poor pun) to sound like injector wiring loom, but could be injectors themselves.
Thanks. Will have a read of the thread.
Well I managed to download a workshop manual and had a read about the fuel delivery system….
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
When the injector loom "went" on mine it was instant, whilst driving, engine was extremely lumpy, however it did start after stopping. The garage identified it through the codes (which ones I don't know. Fitting a complete new loom solved the problem. |
Thanks for the input David. The problem is, I don't actually know that is the problem yet. I could probably fit a loom if I knew that was the problem. But looking at the fuel delivery diagrams in the manual it could be a pressure sensor, high pressure pump, wiring etc. I can't read any faults with my IID. No longer FF owner but still interested. Present car Jaguar XE
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
hi mikeyjd. on the small filter thingy there should only be one pipe. i see you have another pipe connected at the bottom of the filter as there should be no pipe on this end where did the pipe come from, if its floating spare then you will have a massive vacuum leak. that pipe should belong somewhere else if egr it should be plugged or connected. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8674 ![]() ![]() ![]() |
Could be a breather, had a similar problem on my 530, turned out to be injectors weren't working when the engine was cold.
