Home > Maintenance & Mods (L322) > Water in wheel well
supershuttle
Water in wheel well
Is suppose it had to happen but my car seems to leak into the area under the boot floor. I guess I could just sit in the back and persuade SWMBO to get the hosepipe out and see if I can see where it's coming in from and then look at ways to stop it. OR I could be pragmatic and just drill a couple of drain holes in the boot floor - has anyone tried this is there any downside. Geoff
Post #308692 28th Jan 2015 11:31am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Feel for you there, I have just checked mine and the spare wheel is having a bath!
I notice that the right side cubby had a few water drop in there and the carpet in the corner near the tailgate was damp as well as the edge of the spare wheel cover. Big Cry The left side is bone dry though!
I have searched this a bit and found it could be boot seal or where the tow bar is bolted through, as I don't have a tow bar yet, mine could be ( not convinced mind) the seal. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #308714 28th Jan 2015 1:08pm
supershuttle
Yes, I've been having a look and although I did fit a tow bar recently the carpet on the left is wet (as you look into the boot) so as its higher up I suspect the seal. In the posts £94 is mentioned for a replacement I might try first with some non setting mastic. Maybe Sikaflex 512 or similar Very Happy Geoff
Post #308715 28th Jan 2015 1:19pm
Welshdragon
Be good to know how you get on Bow down
Its strange as the seal is good and the tail gate shuts well on the seal, my carpet ,right side is damp on the side at about 6 ish inches up from boot floor.
A few weeks back the boot floor was an ice rink Shocked ...... Censored annoying and the weather is not letting up here so I can have a proper look either Mad If it dont work.......burn it!
Post #308718 28th Jan 2015 1:32pm
Geoff the replacement boot seals come with NON setting sealant inside them pal... So you remove your old one and CLEAN everything up then the new one seals as you fit it Thumbs Up
If yours has been removed in its life? Then they never really seal back properly Rolling Eyes
Post #308723 28th Jan 2015 1:43pm
duckworthparts
Site Sponsor
£96! Shocked
£76.00inc for the tailgate seal You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #308741 28th Jan 2015 2:12pm
supershuttle
Thanks all,
So to bodge or not to bodge that is the question?
Good news from you Dan, already saved twenty quid, might try the man maths on SWMBO: fitted a new seal and saved twenty quid in the process - sounds OK to me Laughing Geoff
Post #308750 28th Jan 2015 2:35pm
Welshdragon
Bow down
Now thats interesting as I have had the seal off to lower the head lining so I could fit the rear dash camera and wiring ....hmmm need to look closly at the seal in the corners more. If it dont work.......burn it!
Post #308768 28th Jan 2015 3:14pm
Potentially your seal is now 11yrs old and removing/refitting it will have disturbed the already dried out sealant so, may well be your issue sir...
Have you checked the top corners to see weather it has expanded with age/rust... Bow down
Post #308880 28th Jan 2015 11:29pm
supershuttle
I think mine may have got disturbed when they fitted a new tailgate, or more likely the new tailgate can't bed in the existing seal which was bedded in by the previous tailgate - does that make sense? Geoff
Post #308887 29th Jan 2015 12:02am
That'll be it then Geoff... Getting to bolts wiring etc it would have been removed & refitted for sure! Rolling Eyes Rolling Eyes Rolling Eyes
Post #308889 29th Jan 2015 12:06am
supershuttle
So as it was a warranty repair maybe the garage should be fixing Rolling with laughter Geoff
Post #308918 29th Jan 2015 8:14am
supershuttle
Thanks Craig, Just been out to check it has been Censored ing in - I'll try the garage later if I have time but I'm not optimistic. Everything was soaked and needed taking out so this is pretty urgent and needs doing soon - they tend to need a couple of weeks just to get in the door of the service department even though since Ryans intervention they are at least willing. Geoff
Post #308931 29th Jan 2015 9:16am
Geoff, make sure you get it properly dried out too my friend... I guess that is where electrical issues may stem from 5 years down the road Rolling Eyes Thumbs Up
Post #308935 29th Jan 2015 9:24am
Welshdragon
@ Craig , yes I'm thinking more towards the seal now after removing it, tow bar going to be fitted some time soon so will do the seal after that Thumbs Up If it dont work.......burn it!
Post #308943 29th Jan 2015 9:46am
