![]() | Home > Technical (L322) > DPF - manual start |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Pretty sure that the dealers have to hook the car up to the on-site diagnostics kit to get it to run the regeneration process...for a charge of course.
Jimmy_75000 Member Since: 06 Jan 2015 Location: London, UK Posts: 27 ![]() ![]() ![]() |
That's what I am trying to find out.. How I can do a force regeneration like the dealer would do without having to go on the M4 at 10PM every other week to avoid traffic....or without having to go tooth dealer every two weeks...
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
you can buy a DPF dongle which in essence momentarily changes the engine tune, you run it with it fitted, it generates a high EGT and burns it off, once its cleaned out the dongle beeps, you remove it and clean is complete.
i have used these:
shalz Member Since: 28 Jan 2013 Location: where FFRRs roam free...! Posts: 507 ![]() ![]() ![]() |
James, this looks interesting but can you expand on the above please? Does it cause long term issues or damage? MY11 Vogue 4.4 TDV8 - "African Queen" |
i believe the mix it gives to achieve the higher egts is not ideal for a long term solution from an engine reliability perspective. i have no evidence to support this. Cheers
Thank you for the information. that could help me for when I can't actually hit the road to clear the dpf. So with this, it sort of force the regeneration without actually having to drive for as per the manual (ie it will clean the dpf while driving in town)? Range Rover Vogue ‘17 TDV6
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Half an hour on the motorway late at night once a fortnight is nothing compared to cost of a replacement dpf every few months |
the last time i used one it was an amber DPF light. i drove 300m with it fitted before it beeped to tell me it was cleared. Cheers
Thanks! Sounds exactly like what i need Range Rover Vogue ‘17 TDV6
Thanks for that. In 2 minds on getting it as nowhere to do that run properly nearby.... MY11 Vogue 4.4 TDV8 - "African Queen" |
I've ordered one. Will let you know if it does the job. Range Rover Vogue ‘17 TDV6
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16340 ![]() ![]() ![]() |
Please do Jimmy, i for one am interested as to how well it works |
Interested to hear the results as well - thanks Jimmy... MY11 Vogue 4.4 TDV8 - "African Queen" |
