![]() | Home > Maintenance & Mods (L322) > Heated Seat. |
Can't those with warm hands warm up those with a cold bottom? |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1669 ![]() ![]() ![]() |
Interesting - I bought my 2010MY 4 days ago and have been back to question them on it. To me they hardly heat up at all to be honest...
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3658 ![]() ![]() ![]() |
I'm just gonna bump this to see if I get any answers. My 2010 seems to have an intermittent fan under the drivers seat, it's quite handy that you can just stick a finger in to see if it's spinning. Has anyone else had this? Is there a fix? Does anyone have the circuit diagram - or is there one in/on TOPIX.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Geoff,
Ah well, I found that as I can feel the fan under my seat, the filter has fallen off again, and if it doesn't start spinning on switch on I turn it of and turn it on again - the trick seems to be to turn it on slowly.
Sometimes the turning off turning on trick doesn't work in which case I have to turn off and turn on the car (restart) after a few miles as the IIDTool pointed me in the direction of the drivers seat heater losing contact (or maybe never even making contact) with the appropriate ECU.
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
I'll swap my 2003 for your 2010 if you like. My seats heat up super quick! |
Lanby Member Since: 16 Jan 2013 Location: Leeds Posts: 11 ![]() ![]() |
Supershuttle, did you get a resolution to your heated seat problem as mine has started doing the same?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4259 ![]() ![]() ![]() |
Craig Are these the filters? https://www.island-4x4.co.uk/seat-filter-g...36870.html How many per seat? 1 or 2? Your post suggests 2per seat ![]() Ta Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" New Defender D350 90 on order. 1974 Series 3 Lightweight = "Millie" My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16206 ![]() ![]() ![]() |
Thats them Rob, two per seat sir... One in the base and one behind the map flap in the back |
Cheers! I’ll check out the front 2.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 ![]() ![]() ![]() |
A bit of light reading for you here Dr Rob:
