Home > eBay & Bargain Spots > Lovely 22 year old |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
It's not even in its original packaging. |
22nd Jan 2015 11:56pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
23rd Jan 2015 12:08am |
neilw Member Since: 20 Aug 2014 Location: Devon Posts: 39 |
^ so glad you posted that. Thought I'd up by putting 205s on my LSE (replacing the bald ones it came with) |
23rd Jan 2015 9:57pm |
Were the 235's an upgrade/extra then? I have never seen an LSE with 205's fitted! And we have worked on hundreds back in the day! |
23rd Jan 2015 11:12pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3722 |
As I mentioned earlier 235's were never ever fitted to RR Classics as standard - they only started to fit them to the RR with the new P38, also at the same time as they started to fit Freestyle Alloys to Discoveries also equipped with 235's. The RR Classic was just out of production by this time.
23rd Jan 2015 11:25pm |
23rd Jan 2015 11:33pm |
I've still got my last Classic - she is on Goodyear 235's though but other than that she is 100% OE with only 93k miles and every MOT - Plymouth Blue 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
23rd Jan 2015 11:36pm |
Mines Plymouth too |
23rd Jan 2015 11:46pm |
Beginning to lose patience with the LSE
26th Jan 2015 4:45pm |
discowill Member Since: 07 Jan 2015 Location: Wigan Posts: 47 |
I am pretty sure you interior lights stuck on is the MFU (timing circuit) you can tell this as nothing timed e.g. intermittent wipers will work, if it is let me know and I will tell you how to fix this, takes about 10 mins |
26th Jan 2015 4:56pm |
Intermittent wipers were fine, as I was driving in drizzle yesterday so did use them. I ended up pulling the fuse so had no interior lights (or radio). I was planning to check all the door switches, but thinking about it the timer should have cut in to turn the lights off - I'll have have a look at the weekend, so any info about a quick MFU fix might be of use! |
26th Jan 2015 8:21pm |
From memory, didn't the rear gate have a tilt device thing in it that use to stick and leave the interior lights on?
26th Jan 2015 11:22pm |
It is easy, just drop the fuse box under the steering wheel, 10mm bolts, then on the rear is a large multi plug remove the plug and unclip the MFU if its beige it is a latter type or black an early type, remove the covers off the MFU and resolder the joints onto the multi plug as they get dry joints and loose connection, while it's out check the other soldering and resolder if necessary, reseal it plug it back onto fuse box and job done. |
26th Jan 2015 11:23pm |
