Home > eBay & Bargain Spots > Lovely 22 year old
It's not even in its original packaging.
Post #307258 22nd Jan 2015 11:56pm
Shocked Bow down Rolling with laughter ................................... Rolling Eyes Rolling Eyes Rolling Eyes
Post #307266 23rd Jan 2015 12:08am
Vogue
Cam-Tech-Craig wrote:
OEM tyres on a normal Classic were 205's yes... LSE's were 235's sir
Sorry m8, we have been buying Range Rovers new since 1973 : - see under exterior features... Thumbs Up
 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #307510 23rd Jan 2015 9:20pm
neilw
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
^ so glad you posted that. Thought I'd Censored up by putting 205s on my LSE (replacing the bald ones it came with)
Post #307517 23rd Jan 2015 9:57pm
Were the 235's an upgrade/extra then? I have never seen an LSE with 205's fitted! And we have worked on hundreds back in the day!
Bow down Bow down Bow down Thumbs Up
Post #307556 23rd Jan 2015 11:12pm
Vogue
As I mentioned earlier 235's were never ever fitted to RR Classics as standard - they only started to fit them to the RR with the new P38, also at the same time as they started to fit Freestyle Alloys to Discoveries also equipped with 235's. The RR Classic was just out of production by this time.
They always needed a 235 and the 7" RR alloys are slightly too wide for the 205 but to be OE correct they should have 205's. Many owners upgraded to the new profile as their old tyres wore out - simply because they looked better and they became more readily available and usually cheaper than the 205 - as this was the profile most tyre dealers kept in stock in the mid 90's Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #307558 23rd Jan 2015 11:25pm
^ Bow down Bow down Bow down Thumbs Up
Post #307562 23rd Jan 2015 11:33pm
Vogue
I've still got my last Classic - she is on Goodyear 235's though Wink but other than that she is 100% OE with only 93k miles and every MOT - Plymouth Blue Thumbs Up 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #307565 23rd Jan 2015 11:36pm
Mines Plymouth too Mr. Green Thumbs Up
Post #307575 23rd Jan 2015 11:46pm
neilw
Beginning to lose patience with the LSE
It now scares small children and animals due to the backfiring problem it's developed.
Had a flat battery at the weekend as the interior lights are stuck on (something else to add to the list to sort).
Then today I've just realised the MOT is due, so the to do list will get even longer, though as I suspect the backfire has taken out the catalytic convertor i see a SORN on the horizon
Post #308219 26th Jan 2015 4:45pm
discowill
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I am pretty sure you interior lights stuck on is the MFU (timing circuit) you can tell this as nothing timed e.g. intermittent wipers will work, if it is let me know and I will tell you how to fix this, takes about 10 mins Very Happy
Post #308221 26th Jan 2015 4:56pm
neilw
Intermittent wipers were fine, as I was driving in drizzle yesterday so did use them. I ended up pulling the fuse so had no interior lights (or radio). I was planning to check all the door switches, but thinking about it the timer should have cut in to turn the lights off - I'll have have a look at the weekend, so any info about a quick MFU fix might be of use!
Post #308292 26th Jan 2015 8:21pm
From memory, didn't the rear gate have a tilt device thing in it that use to stick and leave the interior lights on?
Mercury switch was it???
Post #308368 26th Jan 2015 11:22pm
discowill
It is easy, just drop the fuse box under the steering wheel, 10mm bolts, then on the rear is a large multi plug remove the plug and unclip the MFU if its beige it is a latter type or black an early type, remove the covers off the MFU and resolder the joints onto the multi plug as they get dry joints and loose connection, while it's out check the other soldering and resolder if necessary, reseal it plug it back onto fuse box and job done. Very Happy
Post #308369 26th Jan 2015 11:23pm
