![]() | Home > Technical (L322) > 20" Wheels |
Full fat not diet Member Since: 16 Nov 2008 Location: Herts Posts: 1209 ![]() ![]() ![]() |
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 ![]() ![]() ![]() |
Thanks for the assistance guys, I went to my local dealer and they confirmed RRS wheels OK for FFRR. You cannot fir the wrong nuts as supposedly the standard nuts will not fit later wheels so no worries there. Just have to change the tyres to correct size now to sort out rolling circumference. |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
\\\dont forget to check the load rating of the tyre |
Thanks chaps you got me so worried I bought a set of Autobiography wheels off Fleabay. Will sell the RRS wheels as soon as the other ones arrive and then I'll check my nuts...it would be rude not to |
Ken, can you help me with load rating, was going to buy tyres from blackcircles as they have a fitter nearby but their website only has speed ratings not load ratings although their tyre descriptions do have a number in brackets after the tyre size. Saw they had a good deal on Goodyear Eagles with a 104 in brackets after the tyre size. |
What size wheels did you buy? I assume 20" |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
try this for all you need to know some is usefull some not but especially about the nuts
yes 20" 7 spoke fitted with 255/50/20. |
Guys just shows you what the LR dealers know. Got my new wheels which are the 7 spoke Autobiographies and measured the diameter of the bolt holes and they are 23 mm. Took the nuts off my SC wheels thinking they would be a straight swap and realised some cheeky |
Just as i suspected |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
The outer diameter of the wheels will always be the same. Thats why the profile gets smaller the larger you go. Otherwise, the speedo will be out. But you knew that already! |
Being playing with Powdercoat again |
I recognise those bad boys |
Week end we are fitting extra thick glass to the Rear 1/4's at the mo |
