Home > Maintenance & Mods (L322) > Puddle Lights |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
http://www.fullfatrr.com/forum/topic12599....dle+lights
22nd Jan 2015 9:25pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
They are not really handed .... you can rotate the logo - FYI Mine are set so the LR/RR logo is straight when you open the door to the first natural 'lock' Land Rover Addict
22nd Jan 2015 9:32pm |
It's quite easy to spot, there is a lug on the projector that rotates the logo Land Rover Addict
22nd Jan 2015 9:42pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
I got these and fitted the other day. Shows how well made they are that when I open the door, the DAB signal all but disappears! Got - 2017 SDV8 Autobiography in Loire Blue
22nd Jan 2015 10:35pm |
Be warned BTW ... I am on set number two (albeit in 18 months) as some NUMPTY left my door open for eons while it was being serviced. Burnt out the logos
22nd Jan 2015 10:38pm |
^ even with the door closed? Got - 2017 SDV8 Autobiography in Loire Blue
22nd Jan 2015 11:05pm |
Er...with the doors closed the lights are off unless your wiring is totally screwed .... are you sure it's two LED lamps that are messing with your DAB????? Land Rover Addict
22nd Jan 2015 11:08pm |
Sorry, you've lost me now. Until I fitted the new puddle lights my DAB was working well. Now, when I open the door, the DAB signal goes completely and when I close the door the signal is restored.
22nd Jan 2015 11:11pm |
Most baffling, the unit (I have fitted) is simply a bright CREE with a Vinyl(?) print in front of the lens - the entire vehicle has LED's/CREE's fitted to replace the standard lamps (only the D1S lamps are original). As it's a 30 second job to pop out the lamps, remove one and see if the DAB blanks, then replace with your standard one and see if that makes any odds (which it shouldn't)..... Land Rover Addict
22nd Jan 2015 11:18pm |
...hang on why would you open the door with the engine on.... Land Rover Addict
22nd Jan 2015 11:20pm |
I was checking them out Got - 2017 SDV8 Autobiography in Loire Blue
22nd Jan 2015 11:21pm |
hehe .... as I said, not sure what the heck could cause the problem as they are not CANBUS lamps, therefore it's simply a CREE with vinyl..... Land Rover Addict
22nd Jan 2015 11:23pm |
The "normal" lights have no effect on the DAB signal. Got - 2017 SDV8 Autobiography in Loire Blue
I suspect it's some form of RF interference. Got - 2017 SDV8 Autobiography in Loire Blue
22nd Jan 2015 11:24pm |
