Home > Technical (L322) > Turbo tdv8
Markos01
United Kingdom 2007 Range Rover Vogue SE TDV8 Bonatti Grey
Turbo tdv8
Running on motorway today 70mph in tdv8 Vogue ,kick down throttle and whoosh ....no power pulled over slowly found oil coming from air cooler ,breakdown man said oil possibly in turbo or seals..just had full main dealer service 1month ago and both egr valves replaced car down 80k f,s,h
Panicking might need replace engine ...possibly turbos..car beautiful cond and gave no sign of fault car started again but I switched off quick was told if oil got into turbo it would keep car running even if I had switched off witchI had done .any ideas folk do I need new turbo
And how is the job to do
Post #305883 17th Jan 2015 5:01pm
Mark, i don't want to comment... which will either A, scare you or B, give you false hope... But nevertheless it sounds like it needs looking at by someone who knows what they are doing sir...
Could be several other things too, which will obviously be looked into before turbo failure sir...
Please do report back your findings Thumbs Up
Post #305887 17th Jan 2015 5:16pm
Markos01
Yes thank you have it in my local garage who replaced the egr valves ,he also has 2sports waiting to have new v6engines installed ...
Mike Aiken in. Lady bank fife has a q of 14 waiting in new engines ,so worried I might have to go main dealer ...
There was a bout half a litre came out of air filter box at side of road ..not much smoke though I'm hoping I caught it and coasted to side of road ..can any one tell me is it a big job to replace the turbos and if so how would you knowe if had damaged engine thanks.
Post #305889 17th Jan 2015 5:28pm
Yes Mark its a very big, time consuming, pita job changing turbo's on a TDV8 sir Rolling Eyes Crossed fingers for you sir Thumbs Up
Post #305893 17th Jan 2015 5:35pm
Markos01
Forgot to say had my car superchipped ...few months back...by reputable garage can this be an issue
Post #305894 17th Jan 2015 5:36pm
Markos01
What kind of monies are we talking please can I get recon turbos ,and if so do I need do both
Post #305897 17th Jan 2015 5:38pm
Mikey
New turbos are £1000 each, for brand new turbos, out the factory
One side is fairly easy to do. Realistically, it's a days work.
The other side, less so. The subframe needs dropped, the diff removed, engine mount off, exhaust manifold off...
They can be done DIY, but it's not for the faint hearted.
Post #305919 17th Jan 2015 6:53pm
