Home > In Car Electronics (L322) > Dash Cam (rear view)
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I am looking at fitting a dash cam and looking for current recommendations an/or any to avoid. Looking on Amazon/Ebay etc... I have seen several with a rear camera which I guess could be handing in case of being rear ended/road rage etc... s well as to supplement the standard reversing camera which is pretty poor and doesn't show the rear bumper which is a pain when parking in close confines.
Questions:
1. Current recommendations for a decent camera (ideally looking to keep with in £50 plus the SD card) and not too big. Also availability of second lead and mount if needed would be an advantage so I could use in my old BMW when going to shows etc... I would prefer to buy from a UK seller
2. Is it worth getting the rear view camera, are these wireless as don't fancy running wires from the rear of the car to the main unit.
3. Is the easiest way to wire the main unit using a piggy back fuse on fuse #7 to a 12v socket
4. If the rear needs power only is there an easy pick up (i would prefer not to have to make holes in the car as currently not leaking.
I have searched and there seems to be a number of different models available based on budget/need/quality etc... so really just looking for current info and thoughts.
Robert
[/list] There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #305242 15th Jan 2015 11:10am
i have a cheap £25 one on my rear window, attached via a suction pad and the wire runs down inside the rear trim to the boot power socket.. ... - .- -.
Post #305246 15th Jan 2015 11:21am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Have a look at my link, just don't fit the camera to the glass, the camera wont like it much!
http://www.fullfatrr.com/forum/topic27439....ash+camera Thumbs Up Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #305255 15th Jan 2015 11:50am
dont know how i missed not wiki'fying that Embarassed , now done Thumbs Up ... ... - .- -.
Post #305256 15th Jan 2015 11:57am
ebajema
I got a camera with two lenses so it sees what happens in front with the forward looking lens, what happens inside and behind with the rear looking camera. If that is something for you, I will look up details (bought it on ebay). MY 2010 5.0 SC Galway green and sand interior!!
Post #305257 15th Jan 2015 11:57am
Welshdragon
Thank you sir Stan Thumbs Up Bow down Bow down If it dont work.......burn it!
Post #305258 15th Jan 2015 12:01pm
rej
Stan, is the socket in the boot not a permanent live, if so do you have to plug in and unplug every time? There is a difference between knowing your sh!t and knowing you're sh!t
Post #305311 15th Jan 2015 4:18pm
rej
This sound like the type I have seen. My main concern with this type would be having to run wires from front to back or have I misunderstood and you have two cameras on the one unit so you see everything behind the driver as opposed to a separate camera at the rear of the vehicle? There is a difference between knowing your sh!t and knowing you're sh!t
Post #305312 15th Jan 2015 4:21pm
my bad rej, its something else i have plugged in there...my dashcam is plugged into the ciggy socket at the back of the centre console... ... - .- -.
Post #305329 15th Jan 2015 5:22pm
hex
United Kingdom 2002 Range Rover HSE Td6 Baltic Blue
Had one of these in my rangy http://www.ebay.co.uk/itm/In-Car-Vehicle-D...2c8593279d
Easy fit and the rear can is powers off the lead from the front can unit . simple to fit just ran the lead under the head lining from the back via the dome lights powers on and off with the car powers from a wire in the front dome light
Great picture from both cams and saves them as separate files on the SD card .they are both small enough to fit out of the way
Post #305379 15th Jan 2015 9:09pm
Why ?
Mine are stuck to the glass - front & rear - I run BlackVue's and they seem fine stuck to the glass.
My rear one is powered from the rear fuse box - and the front one from the glove box fuses - both on a piggy back fuse from a switched live connections Thumbs Up
Post #305382 15th Jan 2015 9:22pm
my front one is stuck with 3m to the windscreen and no problems..
my rear one is on a suction mount so i do have to be careful when closing the tailgate making sure i dont slam it shut, maybe thats the reason welshdragon doesn't recommend it.. ... - .- -.
Post #305388 15th Jan 2015 9:39pm
Ah - I understand now - mine's securely stuck, but I guess slamming the boot doesn't do it much good
Post #305402 15th Jan 2015 10:02pm
Welshdragon
Have a look at the link and the last few pictures, shows what happens when tail gate shut a few times did to the camera picture... Whistle If it dont work.......burn it!
Post #305428 16th Jan 2015 5:41am
ebajema
I have taken two pics of the camera unit, it is a single unit with one lens at the front and the second lens at the back next to the screen. The rear lens is fixed in the housing but the front lens can be moved up and down so you can angle it however you like for both lenses to work properly. MY 2010 5.0 SC Galway green and sand interior!!
Post #305429 16th Jan 2015 6:04am
