Home > In Car Electronics (L322) > Dash Cam (rear view) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
i have a cheap £25 one on my rear window, attached via a suction pad and the wire runs down inside the rear trim to the boot power socket.. ... - .- -.
15th Jan 2015 11:21am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Have a look at my link, just don't fit the camera to the glass, the camera wont like it much!
15th Jan 2015 11:50am |
dont know how i missed not wiki'fying that , now done ... ... - .- -.
15th Jan 2015 11:57am |
I got a camera with two lenses so it sees what happens in front with the forward looking lens, what happens inside and behind with the rear looking camera. If that is something for you, I will look up details (bought it on ebay). MY 2010 5.0 SC Galway green and sand interior!!
Thank you sir Stan If it dont work.......burn it!
15th Jan 2015 12:01pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Stan, is the socket in the boot not a permanent live, if so do you have to plug in and unplug every time? There is a difference between knowing your sh!t and knowing you're sh!t 2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue |
15th Jan 2015 4:18pm |
This sound like the type I have seen. My main concern with this type would be having to run wires from front to back or have I misunderstood and you have two cameras on the one unit so you see everything behind the driver as opposed to a separate camera at the rear of the vehicle? There is a difference between knowing your sh!t and knowing you're sh!t 2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue |
15th Jan 2015 4:21pm |
my bad rej, its something else i have plugged in there...my dashcam is plugged into the ciggy socket at the back of the centre console... ... - .- -.
15th Jan 2015 5:22pm |
hex Member Since: 22 Jun 2014 Location: coventry Posts: 108 |
Had one of these in my rangy http://www.ebay.co.uk/itm/In-Car-Vehicle-D...2c8593279d
15th Jan 2015 9:09pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
Why ? Mine are stuck to the glass - front & rear - I run BlackVue's and they seem fine stuck to the glass. My rear one is powered from the rear fuse box - and the front one from the glove box fuses - both on a piggy back fuse from a switched live connections |
15th Jan 2015 9:22pm |
my front one is stuck with 3m to the windscreen and no problems..
15th Jan 2015 9:39pm |
Ah - I understand now - mine's securely stuck, but I guess slamming the boot doesn't do it much good |
15th Jan 2015 10:02pm |
Have a look at the link and the last few pictures, shows what happens when tail gate shut a few times did to the camera picture... If it dont work.......burn it!
16th Jan 2015 5:41am |
I have taken two pics of the camera unit, it is a single unit with one lens at the front and the second lens at the back next to the screen. The rear lens is fixed in the housing but the front lens can be moved up and down so you can angle it however you like for both lenses to work properly. MY 2010 5.0 SC Galway green and sand interior!!
16th Jan 2015 6:04am |
