![]() | Home > In Car Electronics (L322) > Bluetooth music in 2011 FFRR? |
There's an iPod connector in the cubby box, big socket .... you need that lead and 'shock horror' it's not cheap (read - RIP OFF) Land Rover Addict
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1747 ![]() ![]() ![]() |
Thanks both
Be aware early ones WILL NOT CHARGE your ipod/iphone if its 3GS era and below (no really!?!) Land Rover Addict
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
Check out the following topic re bluetooth music streaming.
Why don't you put all the music on a (big) USB stick. That you can leave in the USB slot and it can be controlled from the steering wheel etc. Just make sure that you have a "clean" set of folders, as it hidden info will slow down operation as Geoff recently found out |
Johnielle Member Since: 04 Oct 2017 Location: New York Posts: 1 ![]() ![]() ![]() |
I have been using BT adapter to stream music via bluetooth. I have the viseeousa 1000 plugged to my 30 pin range rover iPod cable. Works really good, no issues. |
