Home > In Car Electronics (L322) > Bluetooth music in 2011 FFRR?
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
There's an iPod connector in the cubby box, big socket .... you need that lead and 'shock horror' it's not cheap (read - RIP OFF) Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #305153 14th Jan 2015 9:27pm
CEEGEE
comports wrote:
So Do I need a "Special LR" iPod lead. Just picked up my 2010 VSE and tried my own iPod lead in the USB port but nothing showed up...?
Look on fleabay - there are some none genuine ones around, but I got a genuine one from someone who had sold their Sport and was selling the lead - paid circa £16 + post.
I think I am right in saying that some Jaguar leads as well as RRS are compatible (check part numbers) - usually plenty to go at, no need to over pay or pay stealer prices Thumbs Up
Post #305156 14th Jan 2015 9:52pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Thanks both
Will source one on the bay I think... Ash
2016 SDV8 AB
Post #305158 14th Jan 2015 9:54pm
DMRR
Be aware early ones WILL NOT CHARGE your ipod/iphone if its 3GS era and below (no really!?!) Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #305174 14th Jan 2015 10:53pm
B9er
Northern Ireland 2010 Range Rover Autobiography 5.0 SC V8 Java Black
Check out the following topic re bluetooth music streaming.
http://www.fullfatrr.com/forum/topic22727.html Should've been old enough to know better...doh!
Current 2010 5.0 SC Autobiography
Previous 2006 TD6 Vogue SE
Previous 1998 P38 4.6 Vogue Autobiography 50 (No 10)
Post #305183 15th Jan 2015 5:46am
ebajema
Why don't you put all the music on a (big) USB stick. That you can leave in the USB slot and it can be controlled from the steering wheel etc. Just make sure that you have a "clean" set of folders, as it hidden info will slow down operation as Geoff recently found out Smile. http://www.fullfatrr.com/forum/topic29293.html?highlight=usb MY 2010 5.0 SC Galway green and sand interior!!
Post #305184 15th Jan 2015 6:01am
Johnielle
United States 2007 Range Rover HSE TDV8 Alaska White
Re: Bluetooth music in 2011 FFRR?
I have been using BT adapter to stream music via bluetooth. I have the viseeousa 1000 plugged to my 30 pin range rover iPod cable. Works really good, no issues.
Post #452961 4th Oct 2017 3:02pm
