Home > Wheels & Tyres > LTZ Q 285 50 20 |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 345 |
Nobody know ? |
13th Jan 2015 9:02am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35287 |
9th post down,
13th Jan 2015 9:24am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Next to the time and date of each post there's a small icon with a hyperlink to the post. This is the link to the 9th post down.
13th Jan 2015 9:37am |
you dont want to make it tooooooooooooo easy for these newbies david.. ... - .- -.
13th Jan 2015 9:42am |
Sorry Stan, I knew you probably knew that - hence my SMUG KNOW ALL SMILIE.
13th Jan 2015 9:47am |
13th Jan 2015 9:52am |
It was a subtle request for a new smilie, and sure we're really going off topic, but then what do you think are the social effects of a deflationary economic policy? |
13th Jan 2015 9:54am |
if i know what that sentence meant i would answer it.. ... - .- -.
13th Jan 2015 9:59am |
Thankyou gents |
13th Jan 2015 10:01am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
You two |
13th Jan 2015 10:05am |
Just got back from having my LTZs fitted and the drivers side rear seems to be rubbing ,so I've looked under the wheel arch and there seems to be some kind of plastic extrusion that leaves only a gap for a Rizzla paper between that and the tyre and every slight camber to the right you can hear it rubbing...does anybody know what this is please ?
13th Mar 2015 6:08pm |
That ll be the filler nozzle cover in the plastic arch liner... Gently warm it up and bent it in Cliff. You have nearly an inch behind it pal |
13th Mar 2015 8:34pm |
Phew !!! Thanks Craig I was gutted when I heard it,you say gently warm it?,what would you suggest ?? |
13th Mar 2015 9:50pm |
Heat |
13th Mar 2015 9:52pm |
