Home > Technical (L322) > iidtool height adjustment |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35380 |
my fronts are the same height as the rears [760mm] so naturally with the iidtool i 'upped' the fronts by 10mm..when i rechecked the fronts they were now at 780mm so i decreased by 10mm and it went down to 760mm again...by increasing by 5mm i seem to be at 770mm...
11th Jan 2015 1:25pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1775 |
You are adjusting the calibration values, not the height value (though they are both linked)
11th Jan 2015 2:20pm |
the calibration and heights are both separately adjustable mikey, i was adjusting the heights.. ... - .- -.
11th Jan 2015 4:07pm |
But the calibrated values are altered as you adjust the height. That's how the car knows what height it's sitting at |
11th Jan 2015 7:15pm |
agreed , but the height settings are in mm and if you increase by 10mm then it should go up in that value.. ... - .- -.
11th Jan 2015 7:27pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
It should.....
11th Jan 2015 8:27pm |
thats what it says in the GAP manual Tim,
11th Jan 2015 8:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8285 |
There is a + or - 9mm tolerance on the height, maybe that's got something to do with it....
12th Jan 2015 9:37am |
theres no reference in the manual about adjusting the heights in tight tolerance mode nor anything about a 9mm plus or minus so i'm sure its not that..
12th Jan 2015 9:57am |
thanks Pat, sorry Pete ..
12th Jan 2015 5:33pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2266 |
Without going out and having a fiddle my immediate reaction is this is it something like radius and diameter ? if you see what I mean does it locate an imaginary mid point?
12th Jan 2015 5:52pm |
skip the sherry and go straght to the vodka
12th Jan 2015 6:13pm |
Stan...
12th Jan 2015 6:57pm |
i entered 5mm into the ipad in the end Pete and it seems stable at 770mm... ... - .- -.
12th Jan 2015 7:00pm |
