Home > Maintenance & Mods (L322) > Anyone tried to repair water leak on a rear wiper motor?
jon3929
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Thought I'd make an effort to get the rear wash working.....
System full of goo = fixed
One way valve stuck = fixed
Wiper motor transfer tube full of dirt = fixed
Nozzles blocked = fixed
Now the system is all working......
Spindle leak on the wiper motor...... ok not so easy.... Confused
Has anyone had one apart or is it a complete waste of time - it must only be an o-ring or something similar. I saw the earlier RRUK thread on this which suggests it is but I wonder if anyone has actually tried??
Cheers, Jon.
Post #304194 11th Jan 2015 12:24pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
If you mean this?....i have done it and it works a treat.
http://www.fullfatrr.com/forum/topic9924.html GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #304195 11th Jan 2015 12:43pm
jon3929
Not sure how I managed to miss that thread when I searched earlier Confused
Anyway I've got it all apart and yes it looks like that little lip seal was leaking. On the up side because the wash system hasn't worked for a fair while before today the drive mechanism is like new inside.
Seal ordered, standby.
Many thanks for pointing me to the afm thread.
Cheers, Jon.
Post #304215 11th Jan 2015 4:21pm
paulmoran2
You're welcome Jon.
Before you search, check the wiki first ( the link is located at the top of the each page in the banner area) and there's a huge list of useful fixes , guides and checklists.
It's a bit of a quest for forum members to post something ( like that) considered so useful it's " wikified " by the moderator Thumbs Up GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
Post #304220 11th Jan 2015 4:40pm
jon3929
All back together and working a treat Thumbs Up
As in the wiki I also removed the old lip seal and ended up grinding some slightly oversized screws back to a total length of 5.5mm, which worked very well with a 2mm daimeter hole. Just ordered a new non-return valve as that was letting the water back. Thanks to the forum.... Proper job..... Thumbs Up
Post #306113 18th Jan 2015 5:37pm
Got to do that to mine, has started leaking onto the shelf........ Has been for months though so there is a bit of a lack of urgency. There is nothing that can't be fixed with a hammer😜😜
Post #306131 18th Jan 2015 6:41pm
Rolling with laughter I took the trim off to have a proper look at mine, it's leaking slightly too, but hasn't made it as far as the parcel shelf yet - I guess I can ignore it for a bit longer Whistle
Post #306208 18th Jan 2015 10:07pm
