Home > Technical (L322) > Door frame seal tear repair
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
I have a small tear in the front passenger side rubber door frame seal as shown. As it's only a small tear I'd like to repair it if I can rather than replace the seal. Can anyone recommend a suitable adhesive, i.e. one that won't dissolve the seal rubber?
 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #304151 11th Jan 2015 2:06am
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
Door seal
Hi I had mine repaired two years ago . squirt some black silicon in & stick seal down . Never had any problem with it since .
Post #304154 11th Jan 2015 5:36am
FrankRizzo
Thanks for the reply. How long does the silicone take to set? My tear is on a vertical section and I don't want it to run to the bottom before it sets. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #304190 11th Jan 2015 12:09pm
Just in case you decide to change it sir Thumbs Up
http://www.fullfatrr.com/forum/topic29483.html
Post #304307 11th Jan 2015 11:09pm
Swiftman
Seal repair
silicon won't run down just put a bit masking tape or gaffer tape over repair & leave on overnight .
Post #304312 11th Jan 2015 11:19pm
