Home > Technical (L322) > Door frame seal tear repair |
FrankRizzo Member Since: 27 Aug 2012 Location: Frankfurt am Main Posts: 216 |
I have a small tear in the front passenger side rubber door frame seal as shown. As it's only a small tear I'd like to repair it if I can rather than replace the seal. Can anyone recommend a suitable adhesive, i.e. one that won't dissolve the seal rubber?
11th Jan 2015 2:06am |
Thanks for the reply. How long does the silicone take to set? My tear is on a vertical section and I don't want it to run to the bottom before it sets. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
11th Jan 2015 12:09pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Just in case you decide to change it sir
11th Jan 2015 11:09pm |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 |
silicon won't run down just put a bit masking tape or gaffer tape over repair & leave on overnight . |
11th Jan 2015 11:19pm |
