Home > Maintenance & Mods (L322) > 2005 FFRR rear fog lights not working |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I can only ask the obvious , does your car have auto head lights ? Because fog lights only work in manual head light mode on the rotary switch . 2008 MY Supercharged
2nd Oct 2010 4:26pm |
Paul Grainger Member Since: 13 Jun 2010 Location: Mansfield Posts: 23 |
Yes it does.
2nd Oct 2010 4:36pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
paul, what year is your car... V8 facelift Range Rover Autobiography 22" wheels.
2nd Oct 2010 4:47pm |
Its a 2005. The 'inbetween model' as I've heard it described.
2nd Oct 2010 4:51pm |
ok, so just want to check you have not got the 2010 led lightson the back... V8 facelift Range Rover Autobiography 22" wheels.
2nd Oct 2010 4:58pm |
ohh! have you been messing with navcoder? V8 facelift Range Rover Autobiography 22" wheels.
2nd Oct 2010 5:05pm |
Mmmm. Well, yes it has got 2010 rear lights. But they've been fitted for months without any problems (not as yet, anyway!)
2nd Oct 2010 5:18pm |
i think you will find that the fog rear fogs will not work when you use the 2010 rear lights, the lcm is different, i dont think i know any one that has done the conversion has had them working, they had to disconnect them to stop the errors, who done the conversion..?
2nd Oct 2010 5:25pm |
I fitted the LED rear lights several months ago - back in April. When I first fitted them, the fog lights were 'lit' with the tail lights. This was easily solved as 'rear fogs dim with tail lights' is an option that I presume must be normally set to 'on'. I turned this option off, problem solved and the fog lights worked perfectly well independantly of the tail lights.
2nd Oct 2010 5:48pm |
when i bought my mk4 lcm with autolights i could not get my rear fogs to work"super chrged lights" it turned out to be the main switch V8 facelift Range Rover Autobiography 22" wheels.
2nd Oct 2010 6:31pm |
Finally resolved this problem by using the fog light feed to the trailer socket. Not the perfect solution, but a simple wiring mod that at least gets all lights fully functional!
16th Nov 2010 8:49pm |
srk1974 Member Since: 25 Jan 2011 Location: United Kingdom Posts: 1 |
Paul,
25th Jan 2011 7:23pm |
