![]() | Home > Maintenance & Mods (L322) > 2005 FFRR rear fog lights not working |
I can only ask the obvious , does your car have auto head lights ? Because fog lights only work in manual head light mode on the rotary switch . 2008 MY Supercharged
Paul Grainger Member Since: 13 Jun 2010 Location: Mansfield Posts: 23 ![]() ![]() ![]() |
Yes it does.
paul, what year is your car... V8 facelift Range Rover Autobiography 22" wheels.
Its a 2005. The 'inbetween model' as I've heard it described.
ok, so just want to check you have not got the 2010 led lightson the back... V8 facelift Range Rover Autobiography 22" wheels.
ohh! have you been messing with navcoder? V8 facelift Range Rover Autobiography 22" wheels.
Mmmm. Well, yes it has got 2010 rear lights. But they've been fitted for months without any problems (not as yet, anyway!)
i think you will find that the fog rear fogs will not work when you use the 2010 rear lights, the lcm is different, i dont think i know any one that has done the conversion has had them working, they had to disconnect them to stop the errors, who done the conversion..?
I fitted the LED rear lights several months ago - back in April. When I first fitted them, the fog lights were 'lit' with the tail lights. This was easily solved as 'rear fogs dim with tail lights' is an option that I presume must be normally set to 'on'. I turned this option off, problem solved and the fog lights worked perfectly well independantly of the tail lights.
when i bought my mk4 lcm with autolights i could not get my rear fogs to work"super chrged lights" it turned out to be the main switch V8 facelift Range Rover Autobiography 22" wheels.
Finally resolved this problem by using the fog light feed to the trailer socket. Not the perfect solution, but a simple wiring mod that at least gets all lights fully functional!
srk1974 Member Since: 25 Jan 2011 Location: United Kingdom Posts: 1 ![]() ![]() |
Paul,
