Home > General > Do you drop the suspension when parked overnight? |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
In his post 27 Nov 1:01 p.m. in the topic “Air suspension compressor.. are there different types?” (http://www.fullfatrr.com/forum/topic28769.html), miggit suggested that the more you make the (tiny) suspension compressor pump work, the quicker it is likely to wear out. I tend to agree with him, so on that basis I only lower the suspension when absolutely necessary.
3rd Jan 2015 9:38pm |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 |
Ok mixed views thanks. I think it's a good idea to keep something used but perhaps I'll do it once a month or so. In reference to the low range gears, I have not even tested these yet. I've tried the manual sport mode which works a charm.
3rd Jan 2015 10:06pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16267 |
Into N then flick the switch and it should toggle between low & high... Its an electrical motor on the transfer box sir... |
3rd Jan 2015 10:09pm |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 |
Craig,
3rd Jan 2015 10:10pm |
Yours will be switched off from factory Stan... 02-05 retract with ignition... Then because they wore out after 1-2yrs and JLR had to keep changing them under warranty they turned off the function on the 06 "facelift" model... It then became a drivers switchable function from the 09 facelift...
3rd Jan 2015 10:21pm |
Ahhhhhhhh, you're talking about the steering tilt! Sorry, I was still on EAS access mode (or not).
3rd Jan 2015 10:26pm |
Exactly |
3rd Jan 2015 10:28pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The more often you drop your EAS the more you will use the pump to raise it when you drive it, and as the pump only has a plastic piston ring, you'll be buying a new pump before long.
3rd Jan 2015 10:45pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1245 |
@OP.
3rd Jan 2015 10:46pm |
But in access mode there is less air in the "system" - Surely that is a good thing, especially in the cold weather as this therefore means less moisture is likely.
3rd Jan 2015 10:52pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
When I first got the FF I used to lower most times when parked up, now only do once a month if that now. If it dont work.......burn it!
3rd Jan 2015 11:00pm |
The later the car the lower they get when parked over time anyway... |
3rd Jan 2015 11:27pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1652 |
Is a bit sad the amount of comments which relate to the premature failure of the product if it is actually used as intended and a bit of an inditement against the engineering and materials production used on these 50-80K cars.
4th Jan 2015 12:23am |
SKOT, if you keep refilling your suspension with new air, you will be causing more moisture not less. I think its better to suffer the small amount of moisture in the system, rather than refill it with moisture laden air every time you use the car. Besides which, the moisture trap in the compressor is not of a drain off type, it is more along the lines of silica gel and will become exhausted in time. This will mean that one day it wont be able to supply enough air to lift the car, then it will be BONG! time, along with the screen of DOOM telling you your shagged and you can't go over 35 MPH. It's a pain when it happens, and the Great God Sod will make sure that your 25 + miles from home went it happens Yesterday I couldn't spell Engineer... Today I are one!
4th Jan 2015 12:28am |
