![]() | Home > General > Do you drop the suspension when parked overnight? |
Luxury4Paul Member Since: 16 Mar 2012 Location: New Jersey Posts: 119 ![]() ![]() ![]() |
Nope. Only drop it when getting the dogs out of the back. Otherwise it sits in regular ride height. |
markyp Member Since: 04 Feb 2013 Location: essex Posts: 234 ![]() ![]() ![]() |
Leave it at normal hight, only lower mine so it's easier for my grandson to climb in and out of the car. 2004 vogue
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
ok - makes sense. I think that's what I'll do to save it lowering every night and then raising again in the morning, no point really unless there is some other reason, like strain on the suspension etc. if it's not lowered?
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
Access height every time I park, cause I'm rather fat! |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
SC, welcome to the forum, don't worry, if there is a problem with the suspension the RR will not hesitate to tell you in all sorts of ways |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6741 ![]() ![]() ![]() |
^^ what he said! |
ok - figured as much - thanks guys. |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
Hardly ever lower it, only for my mother, 92 and not even 5 foot high. Otherwise I have to lift her in. Think I should get some sidesteps, but I don't like them to much. The question is; would it be better to lower the car when parking? I really don't know. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
I always lower it when parking/parked. Easier to reach the ground. |
At the moment, I come home from work, park on my drive and then press the little button on the driver side, it all lowers. I was looking at fitting side steps but after having a Discovery many moons ago, I chose not to go for them since they used to get slippy and certainly muddy. Each to their own I guess.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I'm with Weegie.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
Always drop the suspension when parking up. Did the same on my previous RRSs too. Makes entry and exit so much easier. Love the way the steering wheel moves out of the way too! |
Always drop mine as it saves the wear on the outside of the seat & I'm 6ft 3"... |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
I never used to. I was always worried that it might not come back up again!
