![]() | Home > Maintenance & Mods (L322) > FFRR Brake Upgrade |
davemfox Member Since: 31 Jul 2010 Location: Chester Posts: 43 ![]() ![]() |
I know this has probably been talked to death, but what's the biggest/best brake upgrade I can do to my 2003 TD6 with standard 18" rims??
Good point - I purchased this second hand, so have no real idea if the pads/discs are OEM parts or something else.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3754 ![]() ![]() |
Dave, we are running 7 RR's all with std brakes, and they are all fantastic - no problems, but they all have either LR or OEM brakes on. And these vehicles are used as LR intended.
its got to be a set of brembos but you will need 20" rims to clear them... V8 facelift Range Rover Autobiography 22" wheels.
You could go for a set of EBC Pads & Discs, they have "Improved Bite" but don't last as long. This is always the trade off though.
I'm not aware of any brake upgrade that can be done with 18" wheels. I think daveo is probably right - you'd need to go to larger wheels to upgrade the brakes.
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 ![]() ![]() |
My brakes are fine at the moment on my TD6 but what do people here recommend i change them to when the time comes? stick with LR disc and pads or opt for another make and advice which other makes you have used.
I'd stick with genuine LR or OEM replacements, my experience is they are more than adequate if maintained and properly set up as LR intended. i.e. pads changed when required, discs changed when required and brake fluid changed.................... when required |
