Home > Maintenance & Mods (L322) > 4 wheel alignment oddity
Yep, seconded for the Hunter system Thumbs Up Si. <This is my name.
Post #302120 31st Dec 2014 8:26pm
How do I get it into tight tolerance mode? Discovery 4 HSE
Post #302212 1st Jan 2015 4:37pm
mzplcg
IID tool, Faultmate etc will do it. Failing that get your dealer to do it, take it for alignment and then back to the dealer to put it back to normal mode.
The difference is normal mode allows 10mm of tolerance before altering air suspension heights and TT mode is 3mm. Don't drive it long term in TT mode though as it makes the compressor work hard.
Cheers. Dom.
Post #302217 1st Jan 2015 5:12pm
OK< so I rang around, Formula 1 centres use the Hunter Supertrak system, but they don't put the car into "tight tolerance mode", only the dealer will do that, so I rang them and they want £120 to do it. I am NOT paying that much. Censored
Just how crucial is this Tight Tolerance mode? Surely it's just mechanical adjustments? In all my years of RR ownership I have never heard of this before Discovery 4 HSE
Post #302330 2nd Jan 2015 3:32pm
i had mine done at imperial tyres in swindon on a hunter setup and they didnt put it into tight tolerence mode.. ... - .- -.
Post #302332 2nd Jan 2015 3:38pm
Thanks Stan, it's not rocket science is it? Big Cry Discovery 4 HSE
Post #302335 2nd Jan 2015 3:41pm
might be for me but not for the chaps that done the alignment Laughing ... - .- -.
Post #302337 2nd Jan 2015 3:44pm
Googsy
I understand tight tolerence isnt required for L322 only for Disco3 and 4.Although if in any doubt it can do no harm. Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #302342 2nd Jan 2015 4:44pm
Not done when aligning mine either .
Post #302347 2nd Jan 2015 5:10pm
Well I couldn't stand it any longer, not even a day!
I took it to my local F1 Autocentre and they got it on the ramps, then I got the "Range Rover? Can you come through?"
I thought, uh oh, here we go. Anyway, the chap talked me through the settings and just how bad they were. Turns out no one had touched the rears and they were far out too.
So, an hour later and £72 lighter I left with a car that runs straight and has a steering wheel pointing in the right direction!
For others interest they don't use Hunters system, but the one they use cost them £24k. Forgotten the name, it will come to me.
Happier now. Discovery 4 HSE
Post #302507 3rd Jan 2015 5:19pm
Googsy
Great news I even left the Jaguar forum to sign in to see how you got on. Glad you got it sorted Adam Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Mercedes CLK
Post #302520 3rd Jan 2015 7:16pm
Thanks Conor!
The system they used is called Supertracker. Discovery 4 HSE
Post #302839 5th Jan 2015 12:42pm
ebajema
Glad it is sorted mate, I would be like you, I hate when stuff like this is not "right" !!! MY 2010 5.0 SC Galway green and sand interior!!
Post #302854 5th Jan 2015 1:50pm
Thumbs Up .
Post #302942 5th Jan 2015 8:54pm
Sandyt
Well done it is one of my major bug bears so know how you felt - good result
Thumbs Up Thumbs Up
Post #302951 5th Jan 2015 9:23pm
