Home > Maintenance & Mods (L322) > Rear wiper blade/arm replacement
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
All,
My 2003 Range Rover 4.4 is in need of the rear wiper blade replacing. As it seems these days you can't buy a strip of rubber anymore, I bought a replacement blade on eBay. What I would like to do is remove the existing arm, rub down and re-paint since it is bubbling and a little rusty.
Am I right in thinking you have to remove the spoiler to do any of this? Even to simply replace the wiper blade?
Are there any new arms that can be purchased anywhere or is my only option to repair the one that is there? I would prefer to purchase a new arm so that I can pop the spoiler off, attach the arm plus blade then re-fit, otherwise I have to allow a day in between to rub down and paint etc.
Post #301345 28th Dec 2014 5:35pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
http://www.fullfatrr.com/forum/topic29176.html
Post #301350 28th Dec 2014 5:41pm
18" wipers can be brought from the pound shops, two in a pack as well. ... - .- -.
Post #301359 28th Dec 2014 5:51pm
scwilson
Thanks all. Will this allow me to actually replace the wiper arm or just the blade? I really don't want to have to take the spoiler off but I am thinking this is what I am going to have to do.
Post #301439 28th Dec 2014 9:07pm
Mark L
Post #9 in the link I provided explains all...
Post #301442 28th Dec 2014 9:10pm
scwilson
Thanks. I realize that refers to replacing the wiper blade but what about the arm. Does this position the wiper stops in allow me to take off the arm as well without having to take off the spoiler?
Post #301510 29th Dec 2014 12:24am
its a spoiler off i beleive... ... - .- -.
Post #301529 29th Dec 2014 8:59am
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
wiper arm is definitely a spoiler off job,
but that's only 2 extra bolts / screws.
the main issue is releasing the arm from the tapered shaft PITA
jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #301533 29th Dec 2014 9:05am
SteveMFr
Site Sponsor
It takes all of 5 mins to remove the spoiler. Well worth doing as the aluminum hub at the base of the arm oxidizes and binds the arm so that next to no pressure is put on the blade.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #301539 29th Dec 2014 9:31am
scwilson
OK thanks folks. It looks to me, in the video clip that I shouldn't need to disconnect any cables, just undo the 3 screws/bolts, slide it towards me and lift up, place on top, then prise off the old arm and fit the new one. It looks simple so I don't believe it Smile
Post #301578 29th Dec 2014 11:36am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
do yourself a favour and nip to "Halfwits" or similar and grab yourself a small puller set. Invaluable for things like this and very cheap.
I got a set like these and they have saved me a few times. There is nothing to lever against for the rear wiper arm if it has seized on (you don't want to use the rear window..!)
5 minute job with a puller Ash
2016 SDV8 AB
Post #301594 29th Dec 2014 12:36pm
scwilson
thanks for the tip!
Post #302434 3rd Jan 2015 12:06am
scwilson
Replaced the whole wiper arm and blade on the rear, easy job, removed the spoiler, lifted the cap on the end of the arm, removed the nut and washer (totally rusted so replace both), put a drop of Bitron on the conical spline and it came off easily.
Post #306512 20th Jan 2015 4:29pm
