![]() | Home > Technical (L322) > Help-Engine not running properly 07 TDV8 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6772 ![]() ![]() ![]() |
Split pipe sounds most likely |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
+ 1.
jayrt Member Since: 01 Dec 2014 Location: Yorkshire Posts: 9 ![]() ![]() ![]() |
Thanks guys will have a look tomorrow, I hope thats what it is and nothing too serious!! 2007 TDV8 VSE |
All the hoses seem ok, maybe air flow meter, EGR? 2007 TDV8 VSE |
Did you check under the mesh on the top hose? There is nothing that can't be fixed with a hammer😜😜
All the hoses are ok, its the right hand bank EGR valve stuck wide open. 2007 TDV8 VSE |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Get it changed poste haste my friend... Will cost you at least one turbo if not an engine if left |
I have only driven 2 miles since it happened, stripping it today, hope its not too bad a job! 2007 TDV8 VSE |
A lot to take off but all quite straight forward sir |
Has anyone any tips or advice before I start, does the scuttle centre panel need to come off to get the manifold out? 2007 TDV8 VSE |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1816 ![]() ![]() |
Thanks for the info, every little bit helps. 2007 TDV8 VSE |
been toying with doing mine as a preventative measure, might not be a job for me on the drive though..... i would be bound to lose some nuts and bolts in the process.
Injector covers can be a right |
