Home > Technical (L322) > Help-Engine not running properly 07 TDV8
jayrt
United Kingdom 2007 Range Rover Vogue SE TDV8 Lucerne Green
Not got as far as I wanted today (too many visitors at home), removed all the wiring harness apart from the back right rear plug (need a mirror to see how to release the connector!) and the two injector covers, as above the lower nuts on the covers are a pain! 2007 TDV8 VSE
Post #302253 1st Jan 2015 9:05pm
jayrt
Thanks for all the help, definitely the RH EGR valve, the plunger on the end of the shaft has come off and was just laid in the gap to the cooler, all back together now, replaced both with new units, at a guess it took me about 8 hours in total, that was being very cautious and making sure everything was removed and put back together systematically, the biggest pain as mentioned above was the lower nuts on the injector covers.
Some numpty had been in there before unfortunately and broke a lug off the plenum, and the RH EGR had a broken bolt left in!!!
As a final note to help anybody else in the future the right hand exhaust was very smoky and if you pulled the inlet hose of the throttle smoke was coming out!! 2007 TDV8 VSE
Post #302732 4th Jan 2015 9:23pm
