![]() | Home > Maintenance & Mods (L322) > Driver Side door handle won't open the door anymore |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2685 ![]() ![]() ![]() |
There is a cable connecting the handle to the locking mechanism, the end will have sheared off, it's identical to a bicycle brake cable. I found it to be a right PITA to replace because I'm a ham fisted |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Looks like I might need this part - FQZ000041 (Front Door Handle Release Cable).
I did it without taking the door card completely off, left everything connected up and had the card resting on a chair, there was enough space. I found the hadest part was getting the internal door handle connected properly, very fiddly indeed. Make sure you seat the cable properly , otherwise the door will cease to open at all, a foolish mistake I made . You can leave the airbag connected but you still need to unbolt it for access. |
Thanks for the advice. I guess I first need to order the part off eBay. I'll leave everything connected as you say, with the exception of the airbag that I will unbolt but not disconnect.
birchyman71 Member Since: 19 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
Did the passenger one on mine removed the door card, didn't touch the airbag, had to remove the door handle and drill the old cable end out as it was stuck solid. Took about an hour altogether |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
If you follow the correct procedure for disconnecting the battery then no matter what you do with the door airbag! As long as its refitted & plugged in when you re-connect the battery you very much limit your risk of A, light coming on & B, harming yourself etc sir...
At 1min 49, the black clip for the internal handle has to come off, for the life of me I couldn't get the damn thing connected again! There is obviously a certain knack to it, but it was blind luck that I got it back on : |
Thanks all. Re disconnecting the battery, I am assuming it is the same as any other car or does the Range Rover have a different procedure? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
it does ,details in the wiki.. ... - .- -.
OK thanks. I'll order the part on eBay. Do you all feel this is likely to be the issue? Lock works ok, the internal handle opens the door ok, it's just the outside handle does nothing and there is no resistance anymore when I pull the handle.
there are two cables, one from the inside handle to the lock and the other from the outside handle to the lock...your outside cable has snapped which is a common FF problem. ... - .- -.
ok thanks. I'll get one ordered. |
I have the part now and was going to attempt the job tomorrow weather permitting. Any last bits of advice before I take the door card off? I don't plan on disconnecting the battery, will just place the door card on the seat if possible and leave as many wires connected as I can. |
Well I finally did this job today. It took me 2 hours as I took it slow and didn't want to rush it. What a |
