Home > Technical (L322) > engine lumpy
fil b
England 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
engine lumpy
Hi all, my vogue l322 sometimes juddery when in idle in drive but ok under normal running/ acceleration, rev counter not fluctuating either seems to be using bit more fuel also, any ideas?
Post #301071 27th Dec 2014 11:17am
Cold be a sticky injector, run a Couple of tanks full of fuel with injector cleaner additive and see if improves, cheapest and easiest place to start. There is nothing that can't be fixed with a hammer😜😜
Post #301075 27th Dec 2014 11:26am
Dean
Scotland 2007 Range Rover Vogue TDV8 Java Black
I had the same symptoms and have started this process ^^^^^^ and am already seeing some good results.
Dean 2006 FFRR TDV8 Vogue
2012 Discovery 4 SDV6 GS
Post #301077 27th Dec 2014 11:34am
ebajema
Especially with the cold weather, the diesel is a bit more viscous so you could be on to something here. I would certainly do this as the first attempt to solve the lumpiness. MY 2010 5.0 SC Galway green and sand interior!!
Post #301083 27th Dec 2014 1:20pm
