Home > Technical (L322) > vibration....... |
Have you looked at your suspension to see if there is play on the suspension arms etc. ?? How are the rear brake calipers doing, ever replaced ?? Have you ever had the gearbox fluid and filter replaced ??
26th Dec 2014 8:55am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
I recently had a vibration which felt as though a front wheel was out of balance which I knew neither of them were.
26th Dec 2014 10:00am |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
thanks guys for your help.......
26th Dec 2014 10:19am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
either a sticking calliper on one of the corners, which can cause a really big vibration, heat test is a good way of checking for this.
26th Dec 2014 12:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
you need to start somewhere so get all four wheels balanced first Sal..... ... - .- -.
26th Dec 2014 12:54pm |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
I had a vibration at low rpm when car warmed up, just before 30 and more of a rumble like a bearing at 60, it turned out to be torque converter |
27th Dec 2014 12:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Start with the most basic Salb... Get your wheels balanced |
27th Dec 2014 9:44am |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
I had a very bad vibration at speed earlier in the year - turned out to be a 'sticky' piston in the N/S rear calliper - new callipers and pads from Dan sorted the problem . It was reasonably easy to find, the wheel got very hot compared to the others - the only problem with the FF is it has so much power that you don't notice the drag as much as on lesser powered cars with slightly sticky brakes. 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!) |
27th Dec 2014 4:11pm |
