![]() | Home > Technical (L322) > vibration....... |
Have you looked at your suspension to see if there is play on the suspension arms etc. ?? How are the rear brake calipers doing, ever replaced ?? Have you ever had the gearbox fluid and filter replaced ??
I recently had a vibration which felt as though a front wheel was out of balance which I knew neither of them were.
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
thanks guys for your help.......
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
either a sticking calliper on one of the corners, which can cause a really big vibration, heat test is a good way of checking for this.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
you need to start somewhere so get all four wheels balanced first Sal..... ... - .- -.
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
I had a vibration at low rpm when car warmed up, just before 30 and more of a rumble like a bearing at 60, it turned out to be torque converter |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16311 ![]() ![]() ![]() |
Start with the most basic Salb... Get your wheels balanced |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 ![]() ![]() ![]() |
I had a very bad vibration at speed earlier in the year |
