![]() | Home > General > I just might |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Hi All,
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
Looks like a really nice example at first glance. Very nice indeed. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7910 ![]() ![]() ![]() |
There is some wear on the drivers door card / armrest. Nothing that can't be sorted.
Update - It was a nice car to be honest. A couple of things needed sorting and he offered me £9K of mine. I may see what he'll do for cash but I did hear of another with 84k on the clock. full history (as the other one) but I know the second one wants to get rid so may have more room to move on it.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
TDV8 has the ZF gearbox which doesn't exhibit the same issues of the GM box in the TD6. Intercooler pipes at top front on engine can split making the TDV8 run rough and smoke under acceleration (easy to fix though). You can get a able to connect your Ipod to the entertainment system or if it has RSE there will be an aux input in the back on the centre console. MY07 has the digital TV 56 TDV8 Vogue SE
Thanks Andy - Neither had RSE but both had an aux in socket in the rear centre cubby (between the front seats)
Later satnav discs are available, not sure how the aux works with an Iphone or Ipod as I don't have either. would doubt you get controls on the touchscreen. Pretty sure there is a dedicated connector cable you can get that plugs into the back of the touchscreen 56 TDV8 Vogue SE
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I run an iPod using the AUX. Sound quality is great, but there is NO control or charging with that. I think that MY07+ can get an adaptor for full functionality. However, it's pricey and takes time to install.
Update...
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6767 ![]() ![]() ![]() |
The sellers a brave man accepted such a low bid, knowing he needs to fix the low end power issue.
Agreed - It "should" be a simple fix but it's up to him to sort it first. Are there any gotcha's I should be wary of..? i.e. could he temporarily fix it so it works as I drive away but 10 miles down the road it goes bang..?
I've had that, as have a few others and it turned out to be a split hose. It could also be a sticky turbo actuator, which I don't think is an expensive fix but if it's a turbo, your fund will need to have a few grand in it!
As was pointed out on mine before they were changed - it's wearing the wrong side vents.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Mark... The rear lights and the front grille are all off an SC too sir |
