Home > General > I just might
Page 2 of 3 <123>
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Every day is a school day. Mr. Green
Post #300739 24th Dec 2014 12:05pm
comports
So do you all think I'm doing the right thing or should I walk away given the faults? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #300740 24th Dec 2014 12:06pm
I doubt anyone will give such a definitive answer. It all depends on how much you trust them to repair it properly and if you decide to have it inspected after that and are happy that all is well.
In the end, only you can decide Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #300745 24th Dec 2014 12:20pm
Mark L
Without me knowing the lengths and capabilities of your own knowledge of FFRRs, may I suggest if you're in any doubt, employ a specialist to go and look over the vehicle. Especially so given the amount of ££ you're about to part with.
Having had work done on mine with Craig at Cam-Tech on 2 ocassions in the last week and having learnt what I have, I wouldn't ever purchase another FFRR without it either coming from him or have him go over it. Thumbs Up
Post #300749 24th Dec 2014 12:34pm
comports
Thanks Alan.
Is there a way to "force" it into limp mode if there is still an issue. If he does a temp fix, (which I won't know) how long might it take to reoccur if there is an issue still.
It will have at least 3 months warranty on it but my add additional to make it to 12 months (~£500) He uses AA warranty.
Sorry - so many questions. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #300750 24th Dec 2014 12:35pm
comports
good shout Mark... Craig - fancy popping to sunny Essex for a brew..? Razz Razz Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #300751 24th Dec 2014 12:36pm
Sorry Ash, I can't answer that question. It will only go into limp home mode if it decides there's an issues that it needs to protect the car from further damage.
As Mark says above, if you have any doubts, but still want the car, you must get a specialist involved to check it out for you.
There are plenty out there, but sadly with RRs, you just can't tell when the next big bill will present itself, so the only thing you can really do is have it checked and even then, you can never be truly sure nothing else will go wrong. It's just part of the privilege of RR ownership Thumbs Up
As for the 3 month warranty, that's worth very little in my experience. Got - 2017 SDV8 Autobiography in Loire Blue
Post #300752 24th Dec 2014 12:40pm
ebajema
The risk with the TDV8 is that there is a major turbo failure and honestly I don't know how high that risk is. However considering the great price you have, that should leave some money in the piggy bank to sort that out. If the warranty is 3 months, first stop should be Craig or another reliable FFRR specialist to give it the once over and make sure everything is hunkydory (as far as that can be seen from the outside).
The gearbox is the same as the older SCs and the biggest "issue" there is the potential failure of the EDS4 solenoid and that is a cheap fix (read my gearbox posts and RRPhil help on others).
If you get the car in good shape (i.e. the low end issue solved) and there are no other concerns, then I'd say you should take the risk.
I said no to a TDV8 because of a turbo that had already failed but if this one is doing OK, just give it a top service (hoses, EGR cleaning etc. etc.) when you get it and you are hopefully fine. MY 2010 5.0 SC Galway green and sand interior!!
Post #300762 24th Dec 2014 3:08pm
comports
thanks guys
I paid the deposit this morning (refundable if the turbo is gone).... He has said because of the low bid he is just selling it on behalf of one of his customers. Therefore will not be giving a warranty and it is essentially a private sale. Not sure he is allowed to do that (against trading standards rules etc) Perhaps Gaz or someone in the know can confirm this.? I'd need to get an invoice from him I guess rather than "Some bloke"
I will most likely put the extended AA warranty on it anyway.
I plan to take it to my LR indy once purchased for a once over so hopefully nothing else will jump out at me. Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #300768 24th Dec 2014 3:37pm
if you give the money to him then he must give an invoice....no warranty is good as you can get him to repair it for a period of 6 months ..
http://www.adviceguide.org.uk/england/cons...faulty.htm ... - .- -.
Post #300770 24th Dec 2014 3:46pm
comports
so the key here is to get an invoice from him (not "some bloke")
I know I'm thinking the worst but better to be prepared and not need it than be reckless and get stuffed.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #300772 24th Dec 2014 3:49pm
RR2008HSE
Concerns over car. Concerns over who is issuing the invoice. Just be careful, mate.
CTCraig and Gaz seem to be excellent blokes, ( though I have yet to meet either of them). You may to putting them in an awkward situation asking them to comment on one of their colleagues.
Best of luck.
Post #300803 24th Dec 2014 10:12pm
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
If I were you, I would walk away if you too many questions and doubts about the car and the manner in which the deal is structured.
Post #300818 25th Dec 2014 7:52am
Kingy
If you buy from a dealer then the deal should be with him to protect your rights. You have none in a private sale (as he is now proposing).
Assuming you have paid your deposit to the dealer (and got a sales invoice/ receipt to prove his involvement) then he has SoG Act obligations whether he likes it or not, but that does not mean he will want to honour them given the circumstances. It could prove a real can of worms if you get an issue with the RR a few months into ownership and it is significant enough to involve the dealer. (New turbo etc).
If you are happy to go ahead with private sale/no warranty then treat it as a private sale. Get someone you trust to check the RR fully before you complete the deal and advise on any work required. That price is cheap price for an '07 RR, but only if you don't need to spend a few grand on underlying faults.
Post #300847 25th Dec 2014 1:21pm
Im sorry to come in so late to this thread.... RUN FOR THE HILLS!!! is my advice sir... Sounds like a car/car dealer to be wary of sir!
Post #300850 25th Dec 2014 1:41pm
Page 2 of 3 <123>
