Home > Technical (L322) > Heated Front Screen Operation |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
So I had a new genuine dealer supplied windscreen fitted last week by Auto Windscreens. It all went well, fitted fine, no whistles or leaks or damage.
16th Dec 2014 10:28pm |
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 |
I end up with a thick (about 6") band on the left where the elements are obviously not working. Doesn't bother me too much as it's sort of mid-left, but I'd also love to know if there is a quick n easy fix. |
16th Dec 2014 10:31pm |
thats better than the entire screen not working! Discovery 4 HSE
16th Dec 2014 10:34pm |
I feel your pain nonetheless |
16th Dec 2014 10:36pm |
Maybe they only work with the current flowing one way thru them and if the connectors are he same size they could have mixed them up but for both sides not to work it sounds more like a duff fuse.. While the a pillar trims are off I'd plug s multi meter in and see if you see any juice hitting them. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
16th Dec 2014 11:57pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Yep, should be plug and play, the polarity of the connections doesn't matter, if it worked before they changed it then I would imagine they forgot to plug it in....
17th Dec 2014 12:45am |
The old screen worked fine, you could see the lines clearing in a matter of minutes.
17th Dec 2014 10:59am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
My screen always clears inside and out.
17th Dec 2014 11:32am |
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 |
I had something similar with a Discovery 3 I had until recently. I called Autoglass back after realising it wasn't working six months after they'd fitted a new screen. They discovered the wires hadn't been connected. |
17th Dec 2014 11:33am |
Is it just me or would you have to be thick as a plank not to see two sets of wires and not connect them? Especially as you would have to had disconnected them in the first place.
17th Dec 2014 11:40am |
I'll clean it and try that too, thanks. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
17th Dec 2014 11:42am |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Is there a fuse associated with the heated front screen. Just looked on Topix and couldn't find it! Fuse 15 (front fuse box) is a 30 Amp one for the rear heated screen SDV8 AB MY 2019
17th Dec 2014 11:55am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35270 |
17th Dec 2014 12:14pm |
Is that for a MY2010 Stan? The Topix online manual says 34 is for the fuel filler cap electrics? SDV8 AB MY 2019
17th Dec 2014 12:29pm |
