Home > Maintenance & Mods (L322) > WARNING change your diff oil!!!
Page 1 of 10 12345678910>
Serviced a circa 2006 SC yesterday and once again the rear diff ran out putrified, rusty, water contaminated oil... Car has only covered 70k...
I do suggest the diff's are checked (or better still, oil changed) every 30k as there seams to be a real trend with water ingress in the rear diff casings on SC's & TDV8's...
Approx 40% of the cars we see have this issue...
YOU HAVE BEEN WARNED Rolling Eyes
Post #299259 16th Dec 2014 11:20am
i'm glad i asked you to do mine craig.. Thumbs Up ... - .- -.
Post #299261 16th Dec 2014 11:25am
Good advice. Thumbs Up
Craig, I've changed the diff oil in my 110 many times, but how straight forward is the SC's rear diff to do and what oil would you recommend? Si. <This is my name.
Post #299262 16th Dec 2014 11:26am
A simple filler and drain Bellini... Filler is high on the driver's side, drain is on the bottom... Obviously remove the filler first (otherwise once you have removed the old oil you are stuck if the filler won't budge!) then refill with the correct amount & type of oil (Ducky Dan's your man)
20-30 min job for a novice Thumbs Up
Post #299265 16th Dec 2014 11:34am
n1cktdv8
Mine done last week during Transmission service. All good on mine but garage commented the same; people forget them all to easily. Is this where I put the car details and a bit about myself ?........
Post #299267 16th Dec 2014 11:36am
verydisco
On a lift is is really a straightforward job.
I get them done every other service (and checked at each service of course)
I only use LR fluids, but any branded "compatible" oil will always be better than not changing oil.
While not particularly cheap, renewing oil is MUCH cheaper than replace a diff.
Bear in mind, volumes are very small 1 to 2 liter per diff so even at £30 a liter, it is not than costly (in regards of the car's value) l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #299279 16th Dec 2014 11:59am
JAYBOY
Thanks for heads up Craig Bow down 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #299280 16th Dec 2014 12:24pm
ebajema
Was already on the list for the next (big) service, together with spark plugs, transmission etc. Still not sure if I should put Mr. Tranny or the likes in........... MY 2010 5.0 SC Galway green and sand interior!!
Post #299291 16th Dec 2014 1:34pm
Just done mine Jay, same age & similar miles to yours i think? 19k and mine were just slightly off (a perfectly clean) colour so i changed them anyhow. So, I'm sure yours will be quite clean mate... Low milage cars suffer worse i think Rolling Eyes
Post #299310 16th Dec 2014 2:56pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
how do i know how much oil to refill with ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #299321 16th Dec 2014 4:47pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
I changed mine last month and both diffs dropped oil so clean it was almost a waste.
Transfer case was a different matter though... 200ml came out as opposed to the 1.5L it should be holding!!
Post #299322 16th Dec 2014 4:47pm
verydisco
Mark C
either you check on Topix, possibly even the owner's manual prior to ordering the oils or when filling, you fill up until it goes out the filling hole.
Markc L
I would flush the T-box again soon after you filled it up only 200 ml left must have worn out it so it really could do with a nice clean/flush again. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #299325 16th Dec 2014 5:03pm
Mark L
It's only splash lubricated, so I think I may have got away with it.
I'm guessing the 1.5L is to allow for extreme operating angles the vehicle is capable of.
I know what you're saying though, as that very thought also crossed my mind.
Post #299327 16th Dec 2014 5:11pm
Might do this over xmas.
I guess its best to have warmed the diff so oil comes out easy. Discovery 4 HSE
Post #299370 16th Dec 2014 11:04pm
Adam, its not tremendously thick oil like you would be used to in a Defender! More like expensive engine oil consistency... So no real need to warm it too much pal... Thumbs Up
Post #299372 16th Dec 2014 11:20pm
