![]() | Home > Maintenance & Mods (L322) > WARNING change your diff oil!!! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
i'm glad i asked you to do mine craig.. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Good advice. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
A simple filler and drain Bellini... Filler is high on the driver's side, drain is on the bottom... Obviously remove the filler first (otherwise once you have removed the old oil you are stuck if the filler won't budge!) then refill with the correct amount & type of oil (Ducky Dan's your man)
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Mine done last week during Transmission service. All good on mine but garage commented the same; people forget them all to easily. Is this where I put the car details and a bit about myself ?........ |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
On a lift is is really a straightforward job.
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Thanks for heads up Craig |
Was already on the list for the next (big) service, together with spark plugs, transmission etc. Still not sure if I should put Mr. Tranny or the likes in........... MY 2010 5.0 SC Galway green and sand interior!!
Just done mine Jay, same age & similar miles to yours i think? 19k and mine were just slightly off (a perfectly clean) colour so i changed them anyhow. So, I'm sure yours will be quite clean mate... Low milage cars suffer worse i think ![]() |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 ![]() ![]() ![]() |
how do i know how much oil to refill with ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE ) |
Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121 ![]() ![]() ![]() |
I changed mine last month and both diffs dropped oil so clean it was almost a waste.
Mark C
It's only splash lubricated, so I think I may have got away with it.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Might do this over xmas.
Adam, its not tremendously thick oil like you would be used to in a Defender! More like expensive engine oil consistency... So no real need to warm it too much pal... |
