Home > Maintenance & Mods (L322) > C TEK
J evro
England 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Re: C TEK
J evro wrote:
ken wrote:
J evro wrote:
Anyone use there ctek charger using the 12v acc/ cigarette lighter socket ....and does it work ok, rather than the croc clips onto battery?
Connect direct to the battery using the comfort charge method if no tow option
A what ?
Google .........ah I see what you mean now this would be handy if you could bring it through the bulkhead and into the glovebox ......anyone done this or have any advice ?
Thanks again
Post #289967 31st Oct 2014 2:17pm
J evro
Help!.....bought the Ctek7 last week ,was planning to connect it up tonight but I've lost the instructions I have the cig lighter adaptor and live feed accessory socket in rear,
What mode do I put unit on for the pulse charge so it can be left on as I'm going away ........
Can't remember if it was supply or recondition then it goes into pulse mode and charges when volte drop below a certain level
Post #299110 15th Dec 2014 5:06pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Normal for normal battery. Snow flake setting for AGM battery. Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #299111 15th Dec 2014 5:09pm
J evro
Sorry Nomad was editing my post to add piccie when you replied ,
so is it just put it on normal and it will do a full charge then automatically go into pulse charge if / when required ?
Thought I read it was either supply or recon somewheres ( but that was a week ago and my memory is pants haha)
Post #299113 15th Dec 2014 5:18pm
looking at the manual Normal, AGM, Recond all seem to go to pulse as stage 8. Seems to hold step 7, float upto 10 days then goes to pulse if i understand what they are saying correctly.....
so use normal setting as far as i can tell Thumbs Up
 There is nothing that can't be fixed with a hammer😜😜
Post #299123 15th Dec 2014 6:00pm
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
How often would you recommend connecting the charger ? Every night, every week or once a month ?? Thanks in advance Thumbs Up
Post #307145 22nd Jan 2015 6:30pm
J evro
All depends on how often you do not use your FF , glad to report I've just been away for a month and had it on pulse mode whilst away and returned to a fully charged battery and started straight away ( should have bought one years ago )
Post #307155 22nd Jan 2015 6:53pm
Steverr
Which one did you get ? The 5.0 or 7.0 ?? Plugged in the 12v socket in the luggage compartment ? Thumbs Up
Post #307158 22nd Jan 2015 6:56pm
supershuttle
I don't use a Martin one as I didn't spot them until I had bought all the bits and made one myself - if wish I had seen Martins sooner as it would have saved me time and trouble Very Happy
If you don't have a towbar then on my last RR only the socket in the boot stayed live but the C-Tek comes with connectors you can leave on the battery terminating in a quick release plug
I just used to connect it on cold nights so I could run the FBH in the morning on my old diesel RR, my new petrol doesn't have a FBH Big Cry
It's all automatic so when to battery is fully charged it goes into a trickle/conditioning mode.
MXS 5.0 Geoff
Post #307172 22nd Jan 2015 7:48pm
J evro
I have the 7.0 and just plug it onto the rear 12v socket
Post #307233 22nd Jan 2015 9:52pm
