Home > General (L405) > Engine Tuning Module affects suspension on L405 4.4l SDV8 |
Hobo729 Member Since: 14 Dec 2014 Location: Limassol Posts: 43 |
Having had good results with a tuning module on my 2008 3.6l TDV8, I decided to try doing the same to my 2013 4.4l SDV8 and after a lot of webcrawling, chose a RaceChip Ultimate. The most noticeable effect on the car was not the performance improvement expected but a significant change in the quality of the ride. Gone was the magic carpet ride and instead, there was the sort of ride you would expect by changing from 20" wheels to 22" wheels - my car has the standard 21".
14th Dec 2014 12:27pm |
I do understand your concerns - some of the cheap tuning boxes are certainly best avoided as they get up to all sorts of tricks which can lead to a real mess of problems - some very serious. However, many of the professionally engineered boxes can give really good results as I found with my 2008 3.6l TDV8. The power increase was amazing and even better was the real fuel economy increase - up from at best 24mpg to a genuine 28mpg and 30mpg possible with a light right foot. These figures were not those as shown by the OBC but worked out from the mileometer and fuel put into the tank. The car drove like a dream and covered a very reliable 96,000 miles with no problems.
14th Dec 2014 3:03pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
The "lag" from rest seems to be a diesel Land Rover feature - they all seem to have it, whatever the engine. |
14th Dec 2014 3:23pm |
I've just found a thread about Dynamic Mode - could this be what is being activated by the tuning box electronics? The suspension certainly firms up and is tighter in the bends. Just an idea:) |
14th Dec 2014 3:42pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
I would say that as the active suspension will measure G forces and react accordingly, fit the box and this is whats happening, if it was the same with both boxes then it must be the car that is changing things.....
14th Dec 2014 6:12pm |
No Dynamic Mode for the L405.
14th Dec 2014 7:48pm |
I fully agree - you would expect these tuning guys to know what goes on within the cars 'brains' as obviously some vehicles (like mine) have very sophisticated systems which are probably not common on mundane stuff.
15th Dec 2014 10:01am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
I looked at a lot and went with these http://www.pro-bitz.com and worked a charm for years like a rocket off the mark if I need it and never caused a problem any good? _____________________________________________________
15th Dec 2014 10:28am |
Aeroresh Member Since: 31 May 2008 Location: North Wales Posts: 137 |
You're better of going to DMS...More expensive but they know what they're doing and you're more likely not to be doing your car more harm than good.
15th Dec 2014 12:30pm |
I think you go about it the wrong way. Ditch the diesel and get a 5.0 SC, then you won't need any tuning boxes whatsoever MY 2010 5.0 SC Galway green and sand interior!!
15th Dec 2014 2:24pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
+1 5.0SC all the way! |
15th Dec 2014 6:05pm |
Haha, fine if you don't do many miles or live where fuel is cheap....otherwise its the sdv8.... And a tweaked one will have 95% of the pull of a l405 sc but with double the economy. '14.5 SDV8 Nara Bronze for sale
15th Dec 2014 7:38pm |
Have you had tuning applied to your L405 SDV8 or are you talking of previous experience? Interestingly, my previous "chipped" TDV8 - although it was only the 3.6L version, was notably quicker up to around 85mph than my pals 2007 4.2L SC - and it didn't want to live at the petrol station |
15th Dec 2014 8:34pm |
L405 SC mpg is much better than the L322's SC with the same engine. I think the little difference in fuel economy shouldn't matter so much when you spend that much money on a new or nearly new vehicle. It's like having a nice swimming pool and saving money by half filling it! |
15th Dec 2014 9:35pm |
